Avoiding Scan From String Function errors when converting string to numeric
I have a vi that is getting a number our of a string coming from a serial device.
The problem is if the device sends back bad data my vi errors in scan from string function where I convert the string to number.
Is there a way to check a string and make sure is a number before trying to convert it to a numeric?
Or a way to at least supress the popup error message so my progam does not just stop?
=== Engineer Ambiguously ===
(2,792 Views)
Do you have any special plan for determining what is a valid string for conversion to a number that would be better than what the conversion function is doing already?
Just use the conversion function and make sure you have proper error handling.  If you leave a function like that where errors are possible without wiring the error out somewhere, than a dialog box will popup.  (Although there is a setting in VI properties/Execution where you can disable automatic error handling (uncheck the Enable box).  That will suppress the popups.  But it is not a good substitute for doing your own error handling in your VI.
If you get a bad conversion, what do you want to do?  Send the error to an onscreen error indicator?  Light up an onscreen boolean LED? Log it to file? Retry the operation?
(2,778 Views)
