Avoiding memory leaks in queues
Sreedhar,
it depends on the datatype you keep in the queue wether you see a "free" or not. If your datatype is static (e.g. scalar numeric), you will not see any difference as Jeff mentioned.
If you are working with datatypes which might have different sized (array, variant), it is possible that a flush "frees" memory since every element allocated for the queue is reinitialized on the default datavalue.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 11 of 12
(753 Views)
yep!! Im dealing with arrays... never thought that there will be a difference if Im using arrays.
Things seems to be more clear now.
Thanks.
Message 12 of 12
(745 Views)
