Avoir Labview 6.1 et 6.2 sur la meme machine
Est il possible d'installer la version 6.2 de Labview tout en conservant la version Labview 6.1 sur une meme machine? (En clair est ce que les 2 installations peuvent etre indépendante sur une meme machine?)
(2,656 Views)
Hi
Yes, you can have two versions of LV installed on the same PC, be only sure to choose a different path when installing the second version.
But something else: There is no LV 6.2 version!!! Do you mean LV 6.0.2?
Luca
Luca
(2,656 Views)
Sure no problem with 2 versions on the same machine but I would be careful about where you install them (like the previous comment said). Especially if you installed 6.1 first and 6.0.2 second.
May I ask.... Why do you want both versions? Is there an advantage to having 6.0.2 on there as well? I can't think of any right off. 6.1 opens all the same versions of LabVIEW VI's as 6.0.2 does. Just a thought.
Good luck.
-scraggs99
(2,656 Views)
