B1500 code
I'm having some difficulty trying to do a simple current-voltage sweep with the labview driver provided for the Agilent B1500A. I would also like to perform frequency measurements using the CMU. Could someone assist me by posting sample code? Thank you.
(4,298 Views)
What have you attempted so far? Post your code. This isn't a forum to do someone's homework problem.
(4,275 Views)
Hi, can you post your code. I am also using  the same machine, but unable to do any programming.
Thanks and regards,
Rajesh Agarwal
India
(4,184 Views)
You may not get much help from this thread; it's two years old.  Maybe try searching the forums, then start a new thread.
https://www.google.com/search?q=site%3Aforums.ni.com+Agilent+B1500A
Jim
(4,167 Views)
