bitstream into decimal values
I have read a sound file and  converted the mono 8-bit content (The data is an array of decimal values 125,126,124,126,129.........)
(in the sound file read.vi) into binary stream and used the data for modulation(PSK). Now after demodulation I've to convert the bit stream back into original decimal values to compare the original (baseband) power spectrum.
How to convert the output bitstream into decimal values(like 125,126,124........).
How to do this?
Scan/Format string will not work here.
I've done the decimal to binary conversion like this
Celia
Message 1 of 16
(7,940 Views)
Hello celia,
maybe this could help you...
Btw. I would not call it a binary stream. It's a stream of I16 values in your case!
Message 2 of 16
(7,933 Views)
Hello  Gerd,
Thanks for the code It served the purpose.
Celia
Message 3 of 16
(7,921 Views)
I am trying to run your file (decimal to bitstream conversion_and_back.vi) but it is not working with labview 2013 version. It seems like there some old VIs which are not supported by labview any more. Can you guide me how to make it work with labview 2013 or can you please post the new version of the file which is compatible wth labview 2013.
Message 4 of 16
(7,453 Views)
Hi Joseph,
just delete the missing subVI.
It's part of an old toolkit (Modulation toolkit?) and not needed for the purpose of that VI!
Wow, this thread is ancient…
Message 5 of 16
(7,420 Views)
I made the changes as per your suggestion but the design is not working. It is not giving any error but not producing any result. Kindly guide me how to make it work,
I am attaching the new file please have a look at it.
Message 6 of 16
(7,414 Views)
Hi Joseph,
Why not?
At first it loads a *.wav file, which is expected to be in 8bit PCM format (as you remember this VI is very old!). Then the waveform data is converted to a bitstream and displayed in the "Array" array indicator.
In the last part that array is converted back to the (hopefully) original waveform data.
So again: what is not working here?
Message 7 of 16
(7,407 Views)
When I run this file following values appear at sound output.
Sound Quality: Stereo
Rate: 44100
Bits per sample: 16 bits.
Other than sound output paramter it does not show anything.
Message 8 of 16
(7,397 Views)
If you're working with 16 bits, wouldn't that be contrary to the 8 bits the VI is expecting?
Message 9 of 16
(7,394 Views)
Hi Joseph,
I already mentioned the VI expects 8bit PCM data. So why do you choose a 16bit WAV file?
And what's the problem in reading the help for the WAVEFileLoad function? What's the problem in checking the used output of that function?
Are you even trying to understand what that VI does?
Message 10 of 16
(7,390 Views)
