BAR Code QR Code Problem
hmm sir an example or tutorial would have help
if u dont mind.:)
Message 21 of 30
(3,717 Views)
@Zahkay wrote:
but what do u mean by the pseudocode
how the condition should be
since it is in labview. it should be in block diagram yeah..
pseudocode is not c coding
correct me if i am wrong.
Pseudocode
Message 22 of 30
(3,701 Views)
yeah sir
i did understand the pseudocode
but how to interface this in labview
is there any specfic way
Message 23 of 30
(3,694 Views)
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Message 24 of 30
(3,674 Views)
thank u very much for sharing these tutorials
but there is no  psuedocode in those tutorials which will help
to sove the issue of the vi i am doing..
Message 25 of 30
(3,654 Views)
Of course not.
Pseudocode is a short hand way to describe what you want the code to do.
The tutorials are to show you how to program in LabVIEW.
If you can't make the connection between the two to figure out how to program what you want to do, I suggest you go take a more basic programming course.
Message 26 of 30
(3,644 Views)
Have you even glanced at the Boolean palette? Aren't you running with the context help window open?
Message 27 of 30
(3,641 Views)
Hello dennis
yeah i do that. all the time when i have some problem, i check the help and
online resources
but for this issue, i dont have any clue about it.
Message 28 of 30
(3,626 Views)
Okie thank u for the advice sir
Message 29 of 30
(3,625 Views)
Dar All,
Thank you all very much for your help. I have successfully completed this project. I put my results in AND operator, and when both the codes were acquired, then the data was written. Once again, thank you for the efforts.
Qasim
Message 30 of 30
(3,584 Views)
