BARCODE TAIL END WITH CTL+G [^G]=ASCII 7 [BELL]
Hi Labviewer's,
I'm reading a barcode that end whit  ascii code bell [0x07], i want to check  and compere
the end of the barcode if it's end whit ^G or something else, i'm reading the data into control string
but i cant see the ^G.
o.k i know that it's ascii code but i need to compre and check the tail of the barcode how can i do this???
regard's
eyal.
Message 1 of 18
(4,206 Views)
If you send your barcode data to a string control and then set the string control to display HEX data, you should be able to see the codes....
Right click on the front panel string indicator control to get the option to display the HEX codes.
Don't forget to check that the barcode type you are using supports the code you think that you have.
Message 2 of 18
(4,200 Views)
the problem still exist!!!
i try this but it's not solve the problem.
regard's
eyal.
Message 3 of 18
(4,193 Views)
Hi
You could use the "Strin to Bytearray" function. This allows you to compare each character, although it may not be displayed in the string control.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 4 of 18
(4,190 Views)
still can't see the ctl+g;????
regard's
eyal.
Message 5 of 18
(4,188 Views)
Then I'd say it is not there.
How do you get the data? Did you check with another tool if it works?
Using LV8.0
Message 6 of 18
(4,186 Views)
See the attach file.
Message 7 of 18
(4,182 Views)
As you may have seen in my posts, I use LV7.0.
So could you repost your vi as LV7.0 (File>>Save with options>>Save for previous)?
Using LV8.0
Message 8 of 18
(4,179 Views)
see the attached file, also if i read the barcode into dos, i can see at the end the ^G.
Message 9 of 18
(4,176 Views)
I strongly assume you don't read the barcode with the posted vi.
I further assume you have a barcode scanner, which is connected to a computer over rs232 ore something else. If there really is ^G at the end of the data you should receive, there won't be either 0x47 or 0x67, but 0x7 instead.
So tell us more about the whole system.
Using LV8.0
Message 10 of 18
(4,173 Views)
