BERT Tester implementation
I have an NI 7962R FPGA with 6587 adaptor module, PXIe 8135 controller. I need to implement Bit Error Rate testor. My requirment is 200Mbps data rate. How do I implement it? Do I need any some  module specified for BERT testing by NI? Which licensed Tool do I need to purchase?
(4,367 Views)
I am not aware of a BERT toolbox. How much experience do you have with LabVIEW? This is not a trivial effort. Wouldn't a better solution be to buy someone's commericaly available tester and a gpib interface?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,359 Views)
Agree with Mike here... this is definitely a non-trivial development effort.  That said, what little I recall from my days of using a (commercial) BER tester (and don't ask about getting what I used - look up Tautron BERTS-25 and you'll get an idea of how long ago this was), the transmitter generated pseudorandom bit sequences using a maximal-length linear feedback shift register (LFSR), which is a great Google search term (hint, hint).
In fact I used this technique several years later (still in days of yore), only this time I wrote some code in C which generated such sequences.  What makes LFSRs great is that you can always compute the next value from the present one, so synching on the return path data is easy; the rest is all about counting errors, and deciding when you're hopelessly lost (can't get next value to match over several symbol times).
Good luck, sounds like a fun project, especially if the deadline is still off in the haze Smiley Very Happy
Dave
Edit: I re-read my post and all my typos were for the missing letter "u".  I blame the hardware.
David Boyd
Sr. Test Engineer
Abbott Labs
(lapsed) Certified LabVIEW Developer
(4,330 Views)
Yeah right but I was thinking for some NI solution..
This is what I found: https://forums.ni.com/t5/Example-Code/Bit-Error-Rate-Testing-BERT-Reference-Example/ta-p/3996019
(4,318 Views)
