add the elements of a single row/column of a matrix
Hello everyone,
what's the easiest way to add all the elements of a single row or column of a matrix given the matrix and the number of that row/column on LabVIEW ? The output should be a number for each row or column.
Message 1 of 10
(6,682 Views)
I'm assuming you are very new to LabVIEW, otherwise you would know about For loops, indexing, and the Array functions.  In many programming languages, a "matrix" is just a multi-dimension array, but in LabVIEW, it is a different representation of a multi-dimension array.
If you are really working with a LabVIEW Matrix, the easiest way might be to convert the matrix to a 2D array and use the various Array functions to do the work.  Note that once you have the row or column isolated as a 1D array, there is a function on the Numeric palette that will add the array elements for you (so you don't need the For loop to do that).
P.S. -- I underlined "might be", above, because I've never actually used LabVIEW's Matrix functions, but have stuck with 2 (or 3, or 4) dimension arrays.
Bob Schor
Message 2 of 10
(6,668 Views)
Do you  have an arry or a matrix? In LabVIEW they are different datatypes.  The matrix datatype is typically used only when the specialized linear algebra functions are needed.
To do what you ask with the much more commonly used array datatype, use Index Array (array palette) followed by Add Array Elements (Numeirc palette).
Lynn
Message 3 of 10
(6,663 Views)
Thank you both for the quick response and the helpful tips.
Actually my problem was separating each row or column, to be able to use the "add array elements" function. But I realized it can be done automatically once I wire the matrix array through an auto-indexing tunnel of a loop. Then i could simply transpose the matrix to be able to work with rows only or column only.
Arij
Message 4 of 10
(6,636 Views)
Accepted by topic author ArijJendoubi
Arij,
You still have not indicated whether you are using an array or a matrix.
The Transpose should be outside the loop.
This will give you the sums of all rows and all columns.
These are basic LabVIEW constructs and functions. If you do not understand the concepts, please look at the on-line tutorials.
Lynn
Message 5 of 10
(6,620 Views)
I'm using a matrix, and I did place the transpose function outside the loop, and got pretty much the same block diagram you have there.
Thank you though
Message 6 of 10
(6,611 Views)
Yes, for this kind of code it is irrelevant if you have a 2D array or a matrix. same difference.
Is your problem solved?
Message 7 of 10
(6,602 Views)
yes it is.
Message 8 of 10
(6,589 Views)
It is helpful, as the Original Poster, for you to mark the response that you consider "The Solution" as The Solution (in case later visitors with similar questions find your post).
BS
Message 9 of 10
(6,574 Views)
Oh, I didn't know this feature mattered. As you can see, I'm new to labview, AND to this community. But i like it, and i'll do as you said.
Message 10 of 10
(6,544 Views)
