BMP to binary & write bmp on MacOSX
Hi everybody 🙂
I have two questions for you !
First, I need to convert a bmp file into binary.
What i'm supposed to do is : open the bmp fil with a file dialog, unflatten it to use it for other stuffs (convert to greyscale, use a median filter etc), and after modifying it, i would like to save it. So I used the flatten pixmap vi then de write bmp file vi. But here is my problem : it still write the new file into txt, and not bmp ! 😕
Second question : I would like to convert the same bmp file into binary. I know how to go from binary to bmp but not the inverse.
Any help 🙂 ?
Thanks for all !
Valentine
(If you need more information, just tell me !)
(4,281 Views)
Explain how you have done for saving the bmp file to binary file. Post a snippet of your code
(4,277 Views)
Oh god i'm so sorry, i made a mistake in my explanation :
First problem is how to save the modified bmp-file in a new bmp file
and second problem is to convert the same bmp file into binary !
So sorry for the misunderstanding!
(4,275 Views)
Accepted by topic author VGans
Converting simply a file that is in a specific location means you can follow the code shown below
But am not sure about the MacOSX.
(4,270 Views)
Thanks a lot ! 🙂
It's what i needed !!
(4,265 Views)
Hell VGans,
In the example provided I see that a sequence structure is being used.
In this case however you could just remove it, because it doesn't seem to serve a purpose.
Please also check this link about when to (and when not to) use sequence structures:
https://www.ni.com/docs/en-US/bundle/labview/page/determining-when-to-use-sequence-structures.html
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(4,253 Views)
