BNC-2090A
I was wondering if the BNC-2090A comes with the DAQ board protection circuitry built in or whether this has to be put in by the user?
Harry
(2,566 Views)
hax,
From the factory no, the BNC-2090A does not.  However, if you view section 3 of the User Manual.  You will notice there is a jumper set to 0 ohms, you can change this and add a voltage divider.  In answer to your questions yes,  but ultimately this is the responsibility of the end user.
A_Ryan
AES
(2,556 Views)
