BNC 2090A
Hello Dear. I am new for labview and now I using it. I want to make interface  of functional generator and osciloscope using DAQ 6533 and BNC 2090 A. However , I had faced problems in BNC. I couldn't get  light from LED of the BNC, due to that I couldn't  get any input signal from functional geenrator to BNC. Would you tell me how can I fix it? or Is that BNC doesn't work?
thanks.
Message 11 of 20
(1,275 Views)
The 6533 is a digital I/O device so your question does not make much sense. There also aren't any LEDs that would indicate the presence of a signal.
Message 12 of 20
(1,271 Views)
Dear let me explain again, I was connnected the   6533 DAQ card to my laptope   and  BNC board  sing cable to make interface. But  inorder to check  BNC board work properly,the  green  LED (5v) should  display  light , . But for my case it doesn't gives that light.
Message 13 of 20
(1,257 Views)
Dear in noraml condition it may seems like below  when it works  it seems the 1st image .
Message 14 of 20
(1,253 Views)
Are you sure the 2090 is compatible with the 6533? Even if it is, it can't be used to measure an output of a function generator.
Message 15 of 20
(1,247 Views)
Here is my  configuration
Message 16 of 20
(1,237 Views)
I am not  sure about the compatablity of them. How can I know ?
Message 17 of 20
(1,233 Views)
Check the wiring.
Why are you even persisting with this. You simply cannot create an analog input task with the 6533. I've said this 3 times now.
Message 18 of 20
(1,225 Views)
Okay  I will  check the wiring. would you look the picture of my configuration. I already uploaded it.
Message 19 of 20
(1,219 Views)
You just don't get it. I'm done with this thread. It's like banging my head against a wall.
Message 20 of 20
(1,205 Views)
