09-25-2026 08:44 AM
I assume _Enabling_ it will hamper optimization ...
09-28-2026 12:45 AM
Yes, but disabling it does not ensure full optimization, just like it says. That's how I read it.
The help does not say anything more about how "Enable debugging" affects optimization or what else to do to ensure it though.
09-28-2026 02:35 AM
Fair enough, so how _does_ one get full optimization?
10-02-2026 01:27 PM
You can try unchecking debugging
In the Source Files Settings ->
This next one is a bit dubious, not sure if it works. You would add this to your Pre-Build Actions. It sets the compiler to the highest level of optimizations. (You can also change this in the Options >> Environment Setting and then do a mass compile on your project.)
