BUG: Labelled array constant vs build array vs Bundle (array loses label) (LV2019)
So, this is a fairly common design, right?
Qestit Systems
Certified-LabVIEW-Developer
(69 Views)
I don't think the language makes guarantees about what the wire label will be in situations like this so I wouldn't classify it as a bug.
(46 Views)
You could also do the following to ensure that the label survives...
Note that the wire after the build has no name when  probed. it's a bit a can of worms. What if you would concatenate two arrays (same problem:  no wire name, even if both input arrays are named the same!)
In my best practices, I always wire a cluster constant with proper element names to the top of the bundle operation if I later want to do anything "by name".
(33 Views)
