BUG label position
2 bugs regarding label positions:
1. When switching a control to indicator or the opposite, label stays in the same place and doesn't follow the label placement setting.
2. Diagram cleanup ignores label placement setting.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,850 Views)
1. I agree that this is an annoyance, but it may not be a bug. The label position settings are defined for new controls or indicators, according to the help for the Options dialog.  I guess it comes down to semantics: Does converting a control to an indicator create a "new" object?
2. I am not sure what you are seeing here. It seems to work  for me. See before and after Diagram Cleanup images below.
Lynn
B4 Diagram Cleanup.png   Before
After diagram cleanup.png                       After
(2,823 Views)
1. I agree, it can be semantics. Although i feel that changing between control/indicator is a Replace-function, thus remove/create. 🙂
2. Hmm, at home i cant reproduce it, but it basically worked the other way around for me.
/Y
Qestit Systems
(2,802 Views)
