Background adquisition
Hi everybody!!
I would like to ask you for some advice. In my application I need two screens, one shows a whole image comming from a fast video camera adquisition and the other a zoomed image of one zone of the big image.
I developed this feature using an image control and allowing the point Roi, with the invoke node "Get last events" I am able to handle the "clicks" on the image and show on the other screen the zoomed image. The problem comes when I want to work on the zoomed image screen, the other one has the focus and I cant take it to the one which has the functionality.  I tried different custom configurations of "window appareance" in the VI properties, now I have disabled every option "show when loaded... " and I open and close the front panel programmaticly but I doesn't work yet.
Do you have any idea or example to have a look on it?
Thanks in advance!
Maite.
(2,649 Views)
When you configure the second wind do not have it automatically open when called. Instead on the block diagram of the second screen have it open its own front panel. This will force it to the front and make it active.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,645 Views)
