make default screen when i run the program
hi everibody!
i am trying to make a default screen or front panel when i run my program, in vi proterties i have tried to do it, but what happens is that i make a default screen but not what i want...now i am going to explain it<:
when i want to run my program, in the front panel i have to see the scrren i want to see while i am running my program, and i want to make it default, and run in anywhere of the front panel but must appear the selected screen after running it...do you understand me??
can someone help me??
thanks for all!
Message 1 of 11
(4,676 Views)
To answer your two questions: No and Probably...
Can you explain exactly what you are trying to do?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 11
(4,671 Views)
soory mike!!
my english is not very good as your english, i am sorry!
weel i want to make like a default front panel, in labview when you  run a program in the front panel apperas the area you were watching until you have clicked the run button,
so what i want is make a default front panel, and in any where you are from the front panel always have the same fornt panel when i clik the run button...i think is not very simple to explain...tell me again if you don't understand!!thanks mike!
Message 3 of 11
(4,668 Views)
Defenetly you are feeling tough explain what you want to explain. Let me ask you some question
So the default front panel should contain some controls and indicators along with the RUN button or is it some kind of an image you wanted to display?
If only RUN button control alone need to be displayed then what should be displayed when the RUN button is clicked?
Have you tried any VI to achieve what you wanted to do? If so please post.
What kind of function you are planning to perform when the RUN button is clicked?
Try explaining these things for a better solution.
Message 4 of 11
(4,655 Views)
Hi, ala4,
it is quite difficult to understand what you are trying to explain. Could you explain it in Spanish if you feel more comfortable?
Gracias.
Jesús.
Message 5 of 11
(4,633 Views)
hello, hola!!!
quiero tener una pantalla en el front panel fija, es decir, tengo unos mandos en el front panel, botones, leds....entonces al darle a run en el programa, la parte que se queda en el  front panel, es la que se hay justo antes de darle al run, luego puedes moverte cn las barras de dirreccion vertical y horizontal...pero eso no es lo que quiero,
lo que quiero yo es que este donde este en el front panel, me aparezca en la pantalla al dar run todos los mandos leds...lo que tengo que ver vamos, y no andar siempre moviendome con las barras para encontrar el cacho de pantalla que quiero visualizar......
porloque buscar algun metodo para que cuando de al run me aparezca una pantalla que haya selecionado yo con antelacion y sea fija, que no haya ni barras de dirrecion, solo el run y el stop...me entiendes, si no lo entiendes vuelve a decirmelo y intentare explicarme mejor...
gracias!
Message 6 of 11
(4,615 Views)
Hola, Alan,
te muestro varias opciones del VI Properties:
2.- Para redimensionar los objetos del panel frontal si cambias el tamaño del mismo >> escalar objetos PF.jpg
3.- Puedes abrir un panel frontal de un subVI y utilizarlo para configurar o monitorizar. Para hacerlo, selecciona las opciones que te muestro en la captura >> subVI.jpg
Una buena práctica para hacer paneles frontales más compactos y ahorrar espacio sin perder funcionalidad es utilizar el control de pestañas (Tab Control) sito en el panel frontal >> paleta de funciones >> Modern >> Containers >> Tab Control.
Espero que esta información te resulte de utilidad. Saludos!!
Jesús.
Message 7 of 11
(4,600 Views)
Se me ha olvidado adjuntar las capturas Smiley Surprised
Message 8 of 11
(4,597 Views)
gracias por tu ayuda, pero sigo sin conseguir lo que quiero....
si ejecuto el programa del block panel por ejemplo sale al front panel, pero luego no em aparecen todos los controles, tengo ke mover la pantalla para eso...
no hay ninguna manera de krear una pantalla fija en el front panel???
Message 9 of 11
(4,591 Views)
Tienes que poner el tamaño del panel frontal que quieras. Cuando lo ejecutes, se mantendrá el tamaño. También lo puedes fijas en el VI properties como te muestro en la captura.
Message 10 of 11
(4,585 Views)
