Backward Compatibility with Labview 6.0 and 6.1
I am having the same problem as discussed in the following message board of yours:
"how to open a vi (made in version 6.1 labview) in version 6.0"
One of your support staff offered to take a user's version 6.1 vi, open it and Save As a version 6.0 vi.
Could you please do the same thing for me? I have attached a vi that was created using version 6.1, however, I am trying to do some work at home. Unfortunately, I only have version 6.0 at home. Version 6.1 was only installed in my research lab.
In case simply saving the vi as a 6.0 version will not sole the problem, could you take screen shots of the front-panel and block-diagram and then just attach the jpeg's?
Thank you,
Charles
Message 1 of 9
(3,502 Views)
Hi Charles:
I tried to help you save to version 6.0, but is asks for 3 subvis: AI0, AI1 and Motorsub. If you have those, pass them to me, and I will try to include them to the 6.0 version. I will be back online briefly around 8:00-8:30 a.m. PST, before I engage myself onto non work-related activities.
Or else, since you were not meant to be working on the weekend anyways, maybe you will take it easy and visit your lab Monday?
Santiago
Message 2 of 9
(3,502 Views)
Charles, I came back but did not see any activity on this board. If you still need help, I will be back tomorrow....
Santiago
Message 3 of 9
(3,502 Views)
Sorry I missed you, but hopefully there is someone else working today. Here are the reamining sub-VI's.
Charles
Message 4 of 9
(3,502 Views)
I wasn't able to convert a lot of your VI's to 6.0 but here's the .jpg documentation.
Message 5 of 9
(3,502 Views)
The vi compiled with warnings...
I am attaching both the vi and the warnings. Most of which are vi.lib warnings, which I think you might be able to use 6.0's instead
Best wishes,
Santiago
Message 6 of 9
(3,502 Views)
great!
Thanks!
Fight On!
Message 7 of 9
(3,502 Views)
Hey Chuck:
I think I sent you the wrong file…
These are the ones that the program created, after converting to 6.0 (I hope)
Best wishes and Fight on!
Santiago
Message 8 of 9
(3,502 Views)
Message 9 of 9
(3,502 Views)
