I am having the same problem as discussed in the following message board of yours:
"how to open a vi (made in version 6.1 labview) in version 6.0"
One of your support staff offered to take a user's version 6.1 vi, open it and Save As a version 6.0 vi.
Could you please do the same thing for me? I have attached a vi that was created using version 6.1, however, I am trying to do some work at home. Unfortunately, I only have version 6.0 at home. Version 6.1 was only installed in my research lab.
In case simply saving the vi as a 6.0 version will not sole the problem, could you take screen shots of the front-panel and block-diagram and then just attach the jpeg's?
Thank you,
Charles
