Backward install LabVIEW componets
After I installed LabVIEW 2011, I would like to install LabVIEW 8.5.  When I install 8.5, some components will not installed, especially components relating to FPGA.  It will not even let you choose to install or not.  How do I get around that?  Thanks!  The following folders are having problems
vi.lib\LabVIEW Targets\FPGA\RIO
vi.lib\FPGAPlugInAG\
Kudos and Accepted as Solution are welcome!
(2,618 Views)
Hello jyang,
Unfortunately, there are no versions of NI-RIO that are compatible with both LabVIEW 2011 and LabVIEW 8.5 (see http://digital.ni.com/public.nsf/allkb/577cc9a7dcfc73df8625738400116cc3?OpenDocument). Therefore you cannot do LabVIEW FPGA development in both LabVIEW 2011 and LabVIEW 8.5 on the same computer.
You might look into using virtual machines if you need a LabVIEW 8.5 version for testing purposes. Alternately you could set up a hard drive partition with different versions of windows in each portion. You could also set up a second computer for LabVIEW 8.5 and remote into it when you need to develop in 8.5.
Colden
(2,593 Views)
