Bad VI: More specific error?
Is there any way to see why, when i mass compile some vis, i get 'bad vi?' It seems the error message could be more helpful and say why is it bad...
(3,249 Views)
Accepted by topic author Gordal
I believe the bad VI error only refers to VIs which have their run arrow broken. You can open each of them and see the exact reason.
___________________
Try to take over the world!
(3,235 Views)
If you left click on the broken run arrow a list of errors will display in a box. You can then double click on an error and labview will take you to where the error is.
Rgs,
Lucither
"Everything should be made as simple as possible but no simpler"
(3,215 Views)
