Problem with circular buffer
For some reason, whenever my circular buffer is filled and wraps around, right at that moment, my graph screws up for a split second by drawing a line across the graph. But for some reason, this doesn't happen all the time, only sometimes.
The picture is below:
(5,061 Views)
Without the code that is quite hard to say what's going wrong/on.
Ton
My LabVIEW Ideas
(5,037 Views)
(5,035 Views)
Sorry, made a new thread since that one showed "Solved".
It seems the buffer works fine, something is wrong with the data being inserted in there. I don't know why it only messes up with that data.
I managed to capture some messed u p data. I will post it below.
Message Edited by Bilal_J on 04-12-2010 02:46 PM
(5,029 Views)
This only seems to happen when I plot against time...
I don't know why my time data is like that, it shouldn't be, I dont know how it gets so many x values that are the same.
(4,997 Views)
Hi All,
Let's stay with the Original thread since it has more information about this issue. I will be looking at the code as well.  Thanks!
Esmail Hamdan | Applications Engineering | National Instruments
(4,967 Views)
Message Edited by Ravens Fan on 04-13-2010 08:09 PM
(4,958 Views)
