Bad type case Error in DVR
Hi All,
I m facing an issue when using DVR. My code snippet is given below
As shown in the block diagram, I used two different methods for DVR write and Read which are L1&L2 and L3&L4
L1 and L2 is working as expected.
I m getting an error from L3&L4, which is bad type case error (error 1448)
Here I have a class called "Data" and under data I have the child classes , like "SGL Array","Boolean Array" and etc
There is a Communication class and DVR class is inherited from communication class
Can anyone suggest what could be the problem in L3&L4. why is it behaving differently when it is inside a member class VI. I have the same code inside the member class vi which is highlighted in red color rectangle.
Thank you
Vipinraj KK Certified LabVIEW Architect
Message 1 of 10
(7,845 Views)
Can't debug a picture.
Message 2 of 10
(7,814 Views)
Exactly - what's happening in the subvis is where the issue is, and they obviously aren't just what you have outlined as what is in them.
Message 3 of 10
(7,772 Views)
Dear Paul,
Thanks for your reply,
Please find the attached code (DVR Test.7z) . Kindly review the same.
Message 4 of 10
(7,722 Views)
Something is wrong with your .7z file.  I get an error when trying to open it.  Something about an unsupported command.
Please attach a real zip file and not a .7z file.
Message 5 of 10
(7,710 Views)
Please find the attachment in .zip format
Message 6 of 10
(7,706 Views)
In loop L4, you are trying to cast the output of "Communication.lvclass:Read Data Out.vi" to "SGL Array.lvclass".  However at runtime, it does not contain a "SGL Array.lvclass", it contains "Data.lvclass" so the "To More Specific Class" must fail.
Message 7 of 10
(7,673 Views)
But same logic is working in Loop 2
Message 8 of 10
(7,668 Views)
Accepted by VipinrajKK
This is why using error IO is always helpful - you've got a bug in your DVR start method - you're not wiring the output of the DVR write accessor to the output class, so neither loop 3 nor loop 4 is using a valid DVR. After fixing this, both setups work.
Message 9 of 10
(7,640 Views)
Great!
I Didn't connect that.
Thanks a lot.
Message 10 of 10
(7,622 Views)
