Balloon Plots
altenbach shows us in https://forums.ni.com/t5/LabVIEW/How-to-plot-3D-surface-graph-from-X-Y-Z-points/m-p/2415192#M745940 how to plot a sphere on a 2012 style parametric 3d graph.
lots of trial and error later:
Message 11 of 28
(6,351 Views)
Looks best at "cartesian" and "surface-contour"
Message 12 of 28
(6,336 Views)
I don't think putting the vertical angles inside the inner loop is the right thing to do because we don't have the values of all the horizontal angles and the respective pressure level for all the vertical angles.
I converted my 1D array into 2D array by creating 1D arrays of all the values with the same vertical angle and then stiched them together. Attached is the result.
I see no data at around y=1.16 and I don't understand why.
Also, how do I change the color based the value of the radius(sound pressure level)? I want to view the colors like a heat map.
Thanks!
Message 13 of 28
(6,326 Views)
This zick-zack gap on the rendered surface looks odd, I guess we have to find a way to wrap it around completly.
I don't have a solution at hand, but I think this can't be to hard to solve.
Moreover, I can help you instantly with the color issue: Unlinke the CW3dpgraph, the new parametric 3d graph does offer some nicely defined property notes like an intensity graph, which I really appreciate.
The global minimum and global maximum of the 3d graph's y-matrix
(which is labeld as z in the 3d graph'S rendering ...
could you please label the array constants with their proper name e.g. radius(sound pressure level) ?
So we can better communicate)
´defines the numeric range of "Plots:Surface Color Map" Property.
Message 14 of 28
(6,315 Views)
looks like the y array is displayed on the z axis ... i changed the names accordingly, so s, y and z correspond to array, 3d axis and intensity graph
the zick-zack gap  close converge, when we change the divident from 360 to 334 and from 90 to 85 degrees when converting to radians:
Message 15 of 28
(6,308 Views)
Please forgive me for interjecting and repeating myself ...
In that link I share above you will find links to other threads about 3D graphs. One of those links is a thread where I shared code that produced this image.
And another thread I shared code to help people understand how to organize the data presented to a graph with an example that does this.
I will now step back and thank you for allowing my interruption.
Ben
Message 16 of 28
(6,297 Views)
I found a couple of issues with my code :
1) I had vertical angles from -pi/2 to pi/2 but that should have been 0 to pi,
2) the divisor for both the horizontal and the vertical angles should be pi when converting to radians.
After fixing the code, the graph looks good now.. however I am still having coloring issues. I want the the colors on the graph to be associated with the sound pressure level(SPL) of the speaker so I attached the SPL values to the color matrix. I do sort of get the colors on the graph that I want but the relationship between the colors and the SPL values is not 1 to 1. because the color mapping is done on the values of axes which goes from -87 to 87 but the SPL values range from 65 to 110.
it would be great to associate a color with the values in the color matrix
Message 17 of 28
(6,287 Views)
I used the example from Ben's post and used CW Parametric Surface plot as it allows to map the SPL values with the colors.
My only issue with it right now is that I am not able to access the color ramp properties of the graph while the vi is running.
Ben, do you know if it possible to access the color ramp property during run-time?
Thanks!
Message 18 of 28
(6,282 Views)
The code I included in this thread uses the "W" matrix and maps the values to colors.
Ben
Message 19 of 28
(6,267 Views)
Accepted by LVCoder
just for fun,
if we repeat the first column 0 at column 15 in x- y- z-matrix of
, than we can "close" the 3d surface:
Message 20 of 28
(6,248 Views)
