Bars not lining up correctly on Histogram.vi
Hello everyone,
I am trying to get my bars via the Histogram.vi to line up with my X-axis. I have placed three elements in a 1D array of doubles. I have tried for the last three hours to get this right and it is driving me nuts!
Can someone help?
Eric
(3,134 Views)
If you would use the general histogram, you would have more flexibility. At least wire a larger value to the "intervals" input (currently 10).
(3,113 Views)
Accepted by Eric1977
This is what the help file says:
The histogram is a frequency count of the number of times that a specified interval occurs in the input sequence. The width of the frequency bin is
delta_x = (max–min)/m
where m is the requested number of bins. The centers of each bin are set according to the following equation:
center[i] = min + delta_x/2 + i * delta_x.
With double numbers it gets difficult to solve, you need to offset the min value and adjust for the other X values to be centered. If you can live with it a (far from perfect) workaround is to use a large amount of bins (like 200). This way the bars will look centered even if not exactly.
Ben64
(3,107 Views)
ben -  I believe your "far from perfect" workaround will work for what I need. Thank you.
(3,061 Views)
