Basic Programming Problem
I need to develop a structure on the following condition: where when value of n changes, t should display a value as given below.
N ranges from 100 to 1000
T ranges from 35-150
if N>900, T=35
if N>800 and <900, T=40
if N>700 and <800, T=50
if N>600 and <700, T=60
if N>500 and <600, T=70
if N>400 and <500, T=80
if N>300 and <400, T=90
if N>200 and <300, T=120
if N>100 and <200, T=150
(3,905 Views)
Basic answer: use a Case Structure with as many different cases as you need.
Also: your specifications overlooks multiples of 100; what if N = 400, for example?
Once you defined these intermediate cases, you may also divide N by 100 and use the result to index an array containing the output values.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(3,889 Views)
I'm very new to this field, can you provide an example?
(3,884 Views)
if n=400 t=80
(3,872 Views)
Accepted by topic author jtdess5
Personally, I am a fan of using Threshold 1D Array for situations like this.  You get a fractional index, so round down, and then use Index Array to get your T value.
(3,870 Views)
Thank you for helping me
(3,865 Views)
