How to synchronize FPGA and RT?
Hi all,
I am using crio 9076 with followinf modules: 9234 and 9263. I need to synchronize FPGA and RT working at same frequency which is about 2000 kHz. I am using FIFO as communcation method between FPGA and RT. Is that possible? And how it is possible? What method should I use?
Message 1 of 10
(4,972 Views)
I presume you mean either 2000 Hz or 2 kHz...... if you really want 2000 kHz (2 MHz) then I'll let others answer.... Smiley Very Happy
Message 2 of 10
(4,956 Views)
Sorry I meant 2000 Hz. Do you have any solution?
Message 3 of 10
(4,952 Views)
In our RT Application, we use a read timer for the FIFO read together with whether items are still left in the FIFO or not to essentially run off a timer to keep both RT and FPGA synchronised.
Message 4 of 10
(4,949 Views)
I appreciate that my post helped, but I'm busy with my own workload.... If you ask specific questions, I'm sure people in the forum will be more than willing to help.
>clarification< Response to Private Message
Message 5 of 10
(4,934 Views)
Is it possible to get more on the application?
Do you need to lock phases of input and output data?
In general, I would to get the FPGA to do all the timing/sync and let the RT collect and manage things.  Is this possible in your case?
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
Message 6 of 10
(4,926 Views)
Well that is all what I try. FPGA works as hardware/ software and RT is place where I do calculation. The case is as following: I have input and output modules and I run the FPGA for 2000Hz. The input modules works well. Howerver I need RT working as fast as FPGA because I am creating the controller in RT, which is closed loop, which mean it is using the data coming from FPGA therefore it should works at same rate...
Message 7 of 10
(4,921 Views)
Can the algorithm be put on the FPGA?
On RT, are you using a timed loop?
Have you reviewed http://www.ni.com/compactriodevguide/?
ALE Consultants
Message 8 of 10
(4,918 Views)
In PFGA I am using While loop and in RT timed loop. I have red this guide few time Smiley Embarassed . Still can not solve the problem..
Message 9 of 10
(4,914 Views)
ALE Consultants
Message 10 of 10
(4,910 Views)
