Basic Serial Read and Write example used in a graph
Using the read and write example from labview I get responses like "v 250" and "v 3000".  How do I get just the "250" and "3000", as the right type of data, to put in a chart or graph??  Any advice is much appreciated.  Thanks!
(3,018 Views)
Accepted by Rach_77
Best solution is probably to use an instrument driver for whichever device you are communicating with.
The other method would be a simple Scan From String.
(3,012 Views)
Thanks so much! It worked perfectly with the string scan setup you suggested. 🙂
(3,006 Views)
