Basic questions for RS232/422/485 & Modbus
i have to write some libraries for four types above.
But, i only have a normal windows-computer with a normal serial-connection.
Do i see it correct that can then only make "RS232" with this and that 422 amd 485 are then "special" serial-cards?
So for me it seems that 232/422/485 are three different hardware-types.
And only Modbus is a software-protocol that can be created with labview.
Is this correct?
Thanks for help
(4,734 Views)
Accepted by OnlyOne
RS232/422/485 are hardware specific.  Many RS422 UART cards out there will also handle RS485.  Luckily, most of these cards just show up as a COM port, so the software is the same for all 3.
According to Wikipedia, most Modbus devices use RS485 as the hardware layer.  I will admit that I have no exprience with Modbus, so I'm not going to offer any advice on it.
(4,728 Views)
You will definitely need either a plug-in card or an external module to get RS-422 and RS-485. Nowadays most computer don't even have serial ports anymore, and those that do are RS-232. RS-232 is single-ended. RS-422 is differential, and was designed to extend the range of RS-422. RS-485 was an extension that allowed for true multi-drop applications (where you can have many devices on a bus, and any one could be transmitting/receiving).
From a software perspective, as crossrulz indicated, it would all appear as COM ports.
(4,723 Views)
Concerning MODBUS,
you can find a Labview library here:
http://zone.ni.com/devzone/cda/epd/p/id/4756
It's old but does its work...
And here a good tutorial on this protocol:
http://www.ni.com/white-paper/7675/en
Marco
(4,711 Views)
You can keep the single RS-232 serial port, and get an external converter for 422 and 485.
(4,693 Views)
Marco,
I just downloaded the library zip file and there are folders named 71, 82, 85, 86. I have a labview 2010. Which one works for me?
Rgds,
Harry
(4,616 Views)
Those folders are typically for the LabVIEW version.  Just use the 86 one since that would be the latest (LabVIEW 8.6).
(4,613 Views)
