Basic visa write and read example
Format Into String is your friend. Learn to use it.
Message 11 of 13
(3,025 Views)
is this one to see reading value as a number? i mean i am reading value from temp. controller and it is shown is like 35.6 C and i want to show this value inside of numeric indicator or thermometer(inside of the numeric controller). is that possible to get value and show it in thermometer?
Message 12 of 13
(2,987 Views)
You use Format Into String if you have a numeric control and want to use that to send a temperature setting. You use Scan From String to convert a reading from the controller and display it in a numeric indicator such as the thermometer.
Message 13 of 13
(2,981 Views)
