Basler camera
Hi everyone,
I have a basler camera and I want to use it to see a certain process. And sometimes I need to secord the process. for that I created a case structure to have a start recording button in front panel.
The problem is I dont get a proper video, even I record for 30 seconds I get a 0 seond 'video'.
How can I solve this problem?
thanks in adcance
Message 1 of 12
(4,706 Views)
Accepted by Natig
You want to start the video once, then use the "write frame" VI over and over to record each image as a frame of your video.
Message 2 of 12
(4,636 Views)
Accepted by Natig
Is your camera set up so that it "talks" to LabVIEW and is capable of recording a Video?
To find out, do the following:
  1. Open MAX (the Measurement and Automation Explorer).
  2. Plug in your Camera and connect it to your computer.
  3. Does it show up under "My System" under Devices and Interfaces?
If the answer is "No", you need to figure out how to connect it.  Next:
  1. Click on the Camera (in MAX).  On the right, it should pop up a display with some information about the Camera, and should give  you a "Snap" and "Grab" control at the top.
  2. Press "Snap".  Did you get an Image?
  3. Now press "Grab".  Do you get a Video?
Wasn't that easy?  (I'm assuming it worked).
Now, let's take a brief look at your code.  Before putting all the Bells and Whistles into the code, try to get a simple Picture or Video (a "Snap" or a "Grab").  Let the Camera figure out the settings.  Don't start with a "Do Everything" Express VI (or if you must, leave most of the Controls unwired so they take their default values).
Forget the Camera, look at your basic LabVIEW structure.  You have a While Loop that runs until you push Camera, and then it stops.  [Camera?  Isn't "Stop" a better name for this control?].  Inside this (let's call it) "Camera Loop", there is a Case Statement governed by a Boolean called "Start Camera".  [Another spectacularly wrong name -- yes, the code inside the True branch will run as long as you don't press the switch again, but what does it do?  Who knows?  Maybe it creates one (or more) images (depending on the speed of the loop).
Each time it runs, one image comes out and goes to a Case Statement "on top".  If "Start Recording" is False, nothing happens.  If it is True, you open an AVI file, write the (single) image to the file, then close the file.  When/if another image comes in, you do the same thing, overwriting the previous image.  Is this what you want to do?
My advice is to concentrate on writing simple IMAQdx code to do a Snap (single Image) to an Image Window, and when that works, try programming a Grab.
I must say, as I have dabbled in a variety of interesting aspects of LabVIEW, one of the most challenging things I encountered was LabVIEW Vision.  Fortunately, I had a colleague who needed my help straightening out his convoluted VIs, and we more-or-less "taught ourselves" how to do LabVIEW Vision, largely by writing simple little VIs (no Express VIs, please) to "learn the Tricks of the Trade".  Know any colleagues who have do visual processing (even non-LabVIEW -- image processing, with at least 4 dimensions to keep in mind (image width, height, the pixel value, and if video, "time" = Frame Number).
Message 3 of 12
(4,633 Views)
And how can I write it over and over as video? by using while loop? I dont want to record every second of my experiment I want to add like start recording button but it seems a case structure is not a solution for that😑
Message 4 of 12
(4,564 Views)
Thank you for your answer, yes that part was easy and as you advised I made a vi for grab, it also works. Problem arises when I want to record a video with avi. The code that I have written dont produce a viode but a picture.
Message 5 of 12
(4,560 Views)
Solved: create vi was inside the loop. that was the problem.
thanks for answering
Message 6 of 12
(4,550 Views)
Feel free to mark solution and give Kudos for the help
Message 7 of 12
(4,541 Views)
I just noticed that problem with recording still there. The START RECORDING button does not appear to work, I still get the video of whole experiment. For example I make an experiment for 60 seconds but only want to record 20 second of it. now I get whole 60 seconds video. I dont Understand how it can happen, because false case is empty.
vi file attached above
Message 8 of 12
(4,498 Views)
Accepted by Natig
Can you provide your code here as well? I see you're setting your video to playback at 30 fps, is that what your camera is capturing at as well? You may want to do some rough timing characterization on your while loop to see how fast you are actually writing frames to the AVI file.
Message 9 of 12
(4,485 Views)
" is that what your camera is capturing at as well? " -- I am not sure about that, and I don't really know how to make sure at which fps camera is capturing.
Can it be possible that my code is actually working and shows me the recorded video after pressing "start record"? However, is the timing the source of the problem?
" timing characterization" can you please elaborate on how I can do it?
Message 10 of 12
(4,428 Views)
