Baud Rate into a XNET Cluster
In the insert below it shows 500000 being added to the XNET Cluster.
When I try to do the same I find that Baud Rate is not in the pull down menus.
So how do you get it to do what it is showing.
Is there a problem or am I just doing something wrong
Fig 4.5 Create Cluster and Frame in CANFig 4.5 Create Cluster and Frame in CAN
(1,914 Views)
You can probably just use the 64-bit Baud Rate cluster property instead.  NI should update this documentation.
That image is still in the XNET 20.1 documentation (https://zone.ni.com/reference/en-XX/help/372841AC-01/nixnet/databaseprogramming/) and is identical to the page in the old XNET Hardware and Software manual (https://www.ni.com/pdf/manuals/372840k.pdf).  The old documentation mentions a Baud Rate property (that is 32 bits), so the "Baud Rate" property probably got deprecated in favor of the "64-bit Baud Rate" property at some point.
I decided to see if any of the XNET examples show you the correct property, and I found one using the (likely deprecated) "Baud Rate" instead.  It is Editing Database with IO Control.vi (and can be found in the LabVIEW example finder).
You might want to consider posting XNET questions in the Automotive and Embedded Networks forum in the future: https://forums.ni.com/t5/Automotive-and-Embedded-Networks/bd-p/30
(1,865 Views)
