Baud rate of NI-cDAQ 9174
Hello all,
Is it possible to change baud rate for serial communication between NI-cDAQ 9174 and PC or is it problem with my computer because sometimes i get interruption. I am using NI 9239 to measure voltage from LVDT sensor.
Thank you for your help
Best regards
Message 1 of 16
(1,460 Views)
Hi Nomis,
how is the cDAQ9174 connected to your host computer?
How does the NI9239 come into play when asking about "serial communication"?
Message 2 of 16
(1,426 Views)
Hi GerdW,
Thank you for your reply. It is connected with standard USB cable.What do you mean with that last question? It is connected into first sloth of cDAQ9174.
Best regards
Message 3 of 16
(1,415 Views)
Hi Nomis,
You cannot change speed (aka baudrate) of a USB connection…
What exactly is your problem with cDAQ-to-host connection?
So the information on the NI9239 is irrelevant for your problem…
Message 4 of 16
(1,409 Views)
Hi GerdW,
I am using LVDT sensor for measuring displacement of a actuator that is moving from one to other position. This is done by setting start and end position of actuator. I am also reading current position of actuator and sometime it overshoots and I am reaserching what could be the problem. Maybe data is missed sometimes or it is something else (maybe sensor is the problem). I think that electronics part it is fast enough to do that.
I hope now it is more clear.
Best regards
Message 5 of 16
(1,403 Views)
Hi Nomis,
Does the actuator reach its end position even when it overshoots?
How is the actuator controlled?
Message 6 of 16
(1,396 Views)
Hi GerdW,
The actuator is controlled by H bridge mosfet transistors. National instrument  digital output card drives those transistors. Yes everytime it reaches problem happens with higher frequency.
Best regards
Message 7 of 16
(1,380 Views)
Hi Nomis,
Apparently there is a lag in your control loop between AI (reading of position sensor) and DO (driving the H bridge/actuator) which introduces those overshoots. Or the controller is not properly tuned…
Please define "higher frequency"…
Message 8 of 16
(1,375 Views)
Hi GerdW
Yes that are thoughts, Like it works fine on 2Hz and then I change to 3Hz displacment changes for 1 mm something like that. I general that is not much but for measurment is something. I was thinking trying with CompactRIO it has its own processor.
I dont know if I described it before but when you open like a browser on a computer while running control it lags.
Best regards
Message 9 of 16
(1,369 Views)
I have set in DAQ assistant :
Samples to read: 1
Rate (Hz) : 1kHz
I just checked switching time from electronics from low to high is like 700ns.
Best regards
Message 10 of 16
(1,341 Views)
