Baud rate of NI-cDAQ 9174
@NomisG wrote:
I have set in DAQ assistant :
Samples to read: 1
Rate (Hz) : 1kHz
I just checked switching time from electronics from low to high is like 700ns.
Best regards
Not sure what is going on in your program without seeing any code, but trying to read 1 point at a time at 1kHz rate is not going to happen, especially if you are using DAQ Assistant. Typically you use DAQmx functions and stream multiple points to your system as there is overhead with each fetch call; typically about 100 ms data is a good start. Look in the example finder for code.
Message 11 of 16
(840 Views)
Hi mcduff
What is the difference between DAQ Assistant and DAQmx functions. Ususaly it worked fine for applications that I used, just normal reading data. I just set 1 kHz, maybe I don't need that fast.
Best regards
Message 12 of 16
(831 Views)
@NomisG wrote:
Hi mcduff
Best regards
About the same difference as "Riding a bike with training wheels" compared to "Riding a bike." Lots more options, more efficient, more control, and more fun.
Look at this, ignore the first one since you know that already.
https://www.ni.com/en/support/documentation/supplemental/06/learn-10-functions-in-ni-daqmx-and-handl...
Message 13 of 16
(822 Views)
Hello all!
Since I configured CompactRIO now it works great it dosent overshoot that much, maybe 0.1 mm also on higher frequency. Maybe it was just the computer.
Best regards
Message 14 of 16
(779 Views)
What is the difference between RT.vi and PC.vi in project arhicteture when and using CompactRIO in FPGA programing state. Maybe for bigger projects ?
Best regards
Message 15 of 16
(760 Views)
Best regards
These links will help you understand cRIO architecture and how it is different from cDAQ
https://forums.ni.com/t5/Multifunction-DAQ/cDAQ-vs-cRIO/td-p/3003565
https://www.ni.com/en/support/documentation/supplemental/17/specifications-explained--cdaq-and-crio-...
Santhosh
Soliton Technologies
Message 16 of 16
(755 Views)
