Bearing Orbits in a 3D plot
Hello-
I am currently working on a project where I am collecting data from 8 position sensors on a rotating shaft. The position sensors are paired together and each sensor in the pair, is positioned 90 degrees from each.  The pair can be plotted in X-Y to display the shaft orbit.
 I would like to be able to show all 4 orbits together on a 3D plot, but honestly I have never used 3D plots in Labview so I am a little unsure of how to go about this.  Ideally I would end up with something that looked like the attached picture.  The line connecting the bearing would be great but I'll consider it a nice to have at this time.  There are 4 pairs of sensors.
So in summary what I want to do:
1.Plot 4 orbits along an axis with each orbit being further down the axis
2. Have a line connecting the most recent data point to the most recent data point in the other orbits "down the line"
I am mostly interested if you guys think this is possible and what direction would be best for me to start in.
Trent
(4,520 Views)
Ok
After doing some searching it looks like the first part might be pretty easy.  I am a little confused on how to get multiple channels.  I am looking at the help file for the 3D Line Plot Setup VI (LV 2015) and it looks like there is something called "plots in" with something called obj.  I guess I need a crash course in this now . . .I am going to keep hunting.
(4,492 Views)
I am officially stuck!  I have searched for a while but just can't seem to find an example that helps me understand how to get multiple plots onto a 3d Line graph.  Does anyone have any examples of how to use the "plots in" obj to make 3 line graphs that are essentially spaced out as shown in the first post?  this seems like it should be simple but I have not done much with objects before
Please help!Robot Very Happy
(4,400 Views)
Can you share what you have tried so far, even if its a non running VI but contains some sample data, so people can have a look / play,
(4,389 Views)
The create plot line.vi does not require a graph input, it will create an empty object. Simply add the VI 3 times with the x,y,z coordinate arrays.
Alternatively there is an ActiveX version in the Classic palette.
(4,379 Views)
Fantastic.  That worked like a champ.
Now on to Phase two.  How do I connect one moment in time on the graph plotted on the 0 X plane to the same moment in time on the orbit plotted at the .5 X plane.  basically I am trying to wrap my head around how to create the red line in the original picture.
As I think about it some more I am also not sure how useful it will be since I imagine the lines would look like they are stacking on each other and kinda fill in the entire graph. . .
Hmm
Any thoughts?  I was trying to use this concept to see the phasing between the signals and maybe elude to the way in which the rotor is bending. . .
(4,370 Views)
So the line that runs along the X-axis is connecting points with the same index number (time) between the 3 sets? It looks to me like a Bezier curve with only 5 fixed points, beginning and end (Y=0,Z=0 ?) and the 3 intersections with the data sets.
Since I don't want to do your work for you I will tell you how I would approach it. I don't think 3D graph does interpolation so you will have to that yourself if you want to make it as fancy.
You could create an array with interpolation points for the X-axis and make 2 Spline interpolations (e.g. https://zone.ni.com/reference/en-XX/help/371361R-01/gmath/interpolate_1d/), one for X-Y and the other for X-Z.
(4,357 Views)
