Beginner - How to remove a line from a table?
Hi!
I am trying to select a line from a table, and then, remove it. How can I do it?
I couldn' t find any invoke node that could do it for me. Can someone help me?!
Thank you in advance
(2,597 Views)
A table is just a fancy front panel display of a 2D array of strings. To delete a row use "delete from array" on the data.
To identify the desired row, you could e.g. use the coordinates of the "active cell" property.
(2,593 Views)
