binary string to 1 d array
hello,
what i have is an xml string of binary numbers .  i can unflatten the xml string, but is there a simple way to convert the string to a 1 d array of strings. for example
if my input string was 1010 then the array would have
index     element
0            1
1            0
2            1
3            0
the array may be as large as 2^16 or contain around 32k bits.  thank you
(3,272 Views)
Here's one simple possibility.
Message Edited by altenbach on 09-18-2006 09:22 AM
(3,257 Views)
Hi lfoitek,
Here is another solution:
Be carefull that the build array function is connected to the tunnel and not to the N-terminal
But why do you want to store this as an array of strings!
Ton
Message Edited by TonP on 09-18-2006 06:28 PM
My LabVIEW Ideas
(3,250 Views)
And another one.
David
Message Edited by David Crawford on 09-18-2006 05:38 PM
(3,243 Views)
thank you to all
(3,229 Views)
