Beginner question DAQ Assistant
I have a 4-20mA signal that i want to display in a graph in labview. The signal is connected via analog input module to an cDAQ-9185 which is connected to my PC.
In labview i used a while-loop with the condition always on true.
Inside the loop i inserted a DAQ-Assistant and connected its data output to a graph-block.
The DAQ-Assistend on its own already displays the incoming measurement correctly but the graph-block faceplate doesn't.
What could i be missing or doing wrong?
I am a complete beginner with labview.
(1,862 Views)
If you attach your VI, we could help diagnose your code...
(1,837 Views)
