Multiple Cursor positions from one waveform graph
Hi -- I have two single plot cursors on one waveform graph, and I need to know the x-positions of both cursors.  When I create a property node of "cursor position x", it always displays the position of the second cursor, not the first.  I can't seem to find how to specify which cursor's values to read, so it continues to display the position of the second cursor no matter how many property nodes I create.
How can I display both cursors' values?  (I don't want to use a cursor legend, because I need to use these values as indicators to fit the waveform with.)
Brendan
(11,198 Views)
Hi Brendan,
try this. Hope it helps.
Mike
(11,192 Views)
Thanks Mike -- it definitely helps.  Disappointing if that is the easiest way for this problem to be solved, however -- but nonetheless, very much appreciated.
Brendan
(11,188 Views)
You can actually simplify the above by simply autoindexing the array:
Message Edited by smercurio_fc on 05-05-2008 11:35 AM
(11,162 Views)
Thanks for the tip ! But : How do you create that cursor window in the first place ?
NVM - I found it, in Properties/Show cursor legend
(3,490 Views)
