02-25-2008 04:17 AM
Obviously something has changed (and as I think
resulting in a bug) with the handling of refnums when updating
As I found out using probes, my calling vi starting an instance of a template vi with “FP.Open” is reporting a certain refnum (e.g. 0xE1800013), the called vi itself reports another one about itself (e.g. 0xE1900011), and none of them is recognized by the property node FP.IsFrontmost. I used this feature successfully in LV 8.2 to detect which of my image stack players is topmost (because one has clicked on it), so it was possible to change its conversion policy from the main program.
I’m afraid that this feature is not used very often in that way so nobody reported a similar problem in your forum. There should be some way to do this job, as in commercially available image managing programs like Photoshop.
Can you understand my problem? I have already uploaded
an exe file build with
After starting the program Easytrack:
1. Resolution > OK
2. Stack > Load > Test.stk > OK
3. Stack > Display
4. a Player (Nr.0) appears
Repeat Step 3. several times.
You will be able to change the brightness in each player after having clicked on it using the „Display“ panel at the main program.
I hope that you can help me, we need it very urgently.
Many thanks in advance.
Detlef Hof
02-26-2008 09:38 AM
02-27-2008 02:26 AM
Hello Jochen,
I’m already
in contact with the German engineer Alexander Diepold who tries to get my
application running. If there are findings that will be interesting to the
Regards Detlef
02-27-2008 03:02 AM
02-28-2008 02:14 AM
02-28-2008 02:19 AM
