Ben, I am using the default value. (Terminal is unwired)
Terminal is unwired.
(2,567 Views)
I believe the unwired is defaulting to true which says that visa will look for the termination character and pull it out of the data stream. If you want to see CR-LF's you will have to turn this off.
Ben
(2,567 Views)
