Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Ben, I am using the default value. (Terminal is unwired)
HemleJB1
Member
08-15-2002
04:14 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Terminal is unwired.
0
Kudos
Message
1
of 2
(2,564 Views)
Reply
Re: Ben, I am using the default value. (Terminal is unwired)
Ben
Knight of NI
08-15-2002
07:14 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
I believe the unwired is defaulting to true which says that visa will look for the termination character and pull it out of the data stream. If you want to see CR-LF's you will have to turn this off.
Ben
Retired Senior Automation Systems Architect with
Data Science Automation
LabVIEW Champion
Knight of NI
and
Prepper
LinkedIn Profile
YouTube Channel
0
Kudos
Message
2
of 2
(2,564 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
