Best practice to store hardware ids
> Thanks, it seems that ProgramData should be fine
ProgramData would not be correct for Win XP (I think it is AppData in XP).
I'm assuming you would like to do this the same way that other Windows applications operate.
Use the "Get System Directory" function as Kyle suggested, but select "Public Application Data" instead.
To play nice with other applications, add a folder for your company, then a folder for the particular application.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 11 of 12
(1,059 Views)
I normally put my ini file in the same directory as my project/executable.  Then I use Application Directory to get the directory my config file should be in.
GCentral
Message 12 of 12
(1,035 Views)
