Best way to monitor the ON time of something in a minute ?!
Greetings everybody,
I first have to thank everybody offers help to others here.
I have a question regarding the Best way to monitor the ON time of something in a minute.
Say I have an On/Off switch that I want to know how many seconds that it was ON in the last minute (say) .. and reports that to a file or database each minute. So every minute I send a report to the DataBase with the number of seconds the switch was ON in the last minute.
I already made a solution, But it's not that good I think and there is a problem there .. Please check my VI as it describes the solution more than my words here.
Any comment is appreciated.
Thanks in advance.
Ayman Mohammad Metwally
Automation Engineer
Egypt - Cairo
Message 1 of 12
(3,782 Views)
Hello Ayman,
I attached a changed version of your vi. It uses two parallel loops. The communication is made via local variable and controled by a flag. Just have a look to get the idea.
You can do the communication also on different ways like queues...
Message 2 of 12
(3,766 Views)
Hi Ayman,
here´s my trial.
regards timo
Message 3 of 12
(3,763 Views)
Hi Timo,
could you please send an LV7.1 version as well?
Message 4 of 12
(3,758 Views)
I can 😉
Message 5 of 12
(3,753 Views)
Here is a modification of Timo's VI which uses an Event structure, no local variables, and only one loop. (LV 7.1).
Lynn
Message 7 of 12
(3,741 Views)
GerdW,
Thanks a million .. This is the best for me .. Actually I was looking for something like the lower while loop in your code ..
Automation Engineer
Egypt - Cairo
Message 8 of 12
(3,723 Views)
TimoSchott ,
Thanks alot .. Very good idea .. but I think it needs some modifications to suit my needs ... The indicator holding the (ON seconds) must be initialized each interval (one minute second in our example).
Thanks again .. I appreciate it.
Automation Engineer
Egypt - Cairo
Message 9 of 12
(3,722 Views)
johnsold ,
Thanks alot toy you too .. But I think your solution also needs some modifications for the same reason in Timo's solution.
But I really appreciate your help.
Automation Engineer
Egypt - Cairo
Message 10 of 12
(3,718 Views)
