Better way to keep color in an updated string indicator
I wanted to add a feature to my RS232 swiss armay knife application.
Using one string indicator and show the written and read strings in different colors.
The attached program work, however since every update of string results in ONE color the solution found need an rewrite of all colors after each update which results in flicker 😞
and if you log some more data in the indicator it's a bad solution .
One improvement would be to only store blocks of same color ....
Someone with a better idea or solution?
Greetings from Germany
Henrik
LV since v3.1
(3,698 Views)
Defer FP refresh seems to work.
Regards Florian
(3,690 Views)
How about using a List Box instead of string control..  and having the sent and read text in different rows..& obviously different colours..
(3,689 Views)
Regards Florian
My first thought as well.
I did mine to emulate a protocol analyzer where send and recieve are on different lines and also wanted to flag protocol errors so I used a picture control.
Ben
(3,675 Views)
Accepted by topic author Henrik_Volkers
Use these to write strings to a picture control.
(3,657 Views)
Ben & pcardinale
Thank you 🙂
Nice solution, very flexible
I now have to decide which one to choose as solution ...
OK, the vis saved me a lot of work and thinking 😉
Henrik
LV since v3.1
(3,630 Views)
@Henrik Volkers wrote:
Ben & pcardinale
Thank you 🙂
Agreed.
My task here is inspiration.
Pcardinale earned the solution with perspiration.
Smiley Very Happy
Ben
(3,616 Views)
