Big string operation
To import a big array into database, it need to convert the array into a long string and using the string generate a SQL statement.
But the process of generator long string take very long time as the attached vi.
It seems mostly the time is spend on 'concentrate the string' in each loop. May be because the system is keep assign new size memory to the string.
One way to solve it come into mind is define a long fixed size string first and then use string subset replacement everytime. But there seems not funtion of define a fixed size string in LV.
Any suggestion, thanks.
Message 1 of 12
(4,670 Views)
Hi Alex,
no, there is no fixed size string in LV.
The loop runs fast (ok, that's relative Smiley Wink ) in your example, only the "flatten to string" needs some more time (for the first run). On my computer your VI only takes less than 2s. So you have to define this "take very long time" and what timings you need...
Message 2 of 12
(4,662 Views)
Array to spreadsheet string is ALOT faster, though the result isn't identical.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 12
(4,650 Views)
Actually, there is, sort of. In fact, you sometimes need to do so when calling DLLs that expect a pre-allocated string. You use the Initialize Array to create an array of U8 values and then use the Byte Array to String function.
As for your code: Can you provide an explanation of the conversion you're doing? It seems a bit ... convoluted.
Message 4 of 12
(4,635 Views)
Sorry, I have commented off the most time cost part in the first attachment. I have attached again with the original copy.
The array may be even bigger.
I also tried spreadsheet string ever, but it may take around 1min when array is bigger.
I also tried the way smercurio_fc suggested, but when the array size goes up to 800000, the definition also takes around 1min. Any suggestion, thanks.
Message 5 of 12
(4,605 Views)
I'm just curious as to why such a long string.  Perhaps there is a more efficient way to do this?
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 6 of 12
(4,597 Views)
First things you need to initialize the shift register, else the output string grows with every run of the VI. The lenght is 15MB after the first run and 30MB after second run, and so on. (and that's for the 5000x500 input)
Is there some online documentation for the conversion you are trying to do? Seems convoluted.
Message 7 of 12
(4,588 Views)
I have a tdms file around 10M, it need to import the data into center sql database.
Message 8 of 12
(4,587 Views)
10M of what? Bytes? DBL values?
Your 5000x500 DBL sample array is already ~20MB (5000x500x8bytes) and the output is 6bytes/value for a total ot 15MB as I already said.
You mentioned problems going to 80000. Is this still a 2D array? Is 80000 the product of the dimensions or just one of them. Please be very specific with units and describe the problem fully. It is very difficult to understand single-sentence soundbites posts out of context.
Message 9 of 12
(4,578 Views)
Btw, you cant import it directly like that, a SQL command is limited to 8000 characters (if memory serves).
If you need to import it you'll probably want to make 1 insert per tuple/row and loop that.
/Y
Qestit Systems
Message 10 of 12
(4,566 Views)
