Binary File Read
Hello everyone,
I am not that comfortable with binary file reading. I am trying to learn.
I have a vi which logs a sine wave in a binary file.
The Read vi which I have written is not giving the expected data.
Thanks in advance
cooldude
(3,824 Views)
Can you attach it for lv 8.0? or post a screen shot of the vi?
(3,817 Views)
(3,815 Views)
exactly what problem you are facing?
you can check shipping example by NI with keyword BINARY.
Shrenik
(3,805 Views)
What is the data format you are getting in the first place? are you converting it into a binary format and storing it?
(3,802 Views)
Wire a False constant to the "prepend array or string size" input of the Write to Binary File function.
Also, the  "create" constant on the Log Data VI should be "replace or create".
(3,782 Views)
