Registry key with Installer
I know that the subject was already posted but not completed for my case, somebody could help me on this problem, please? Previous post
Thanks.
(3,237 Views)
Thanks.
Have you tried to create a registry key with [TARGETDIR]\\<Your app name> in the installer? The whole installer business is after all based on MSI so you best try to find how that would be solved in MSI and try then to apply that knowledge in LabVIEW.
And reading through one of the posts it would seem to me that this suggestion was already sort of linked to in one of the posts. If this can't be made to work in this way then I'm afraid there won't exist another solution directly in the installer, but I do think it will work.
Message Edited by rolfk on 12-29-2009 10:55 AM
Rolf Kalbermatter  My Blog
(3,210 Views)
Accepted by topic author J.DECHET
Yeeeeeeeeeeeeeeee, find!
You must use [INSTALLDIR] as root of key data.
[INSTALLDIR] corresponds to the user selcted path for installation.
Create your key AppPath then name it [INSTALLDIR]AppFolder\AppSubFolder
where AppFolder and AppSubFolder is your relative path
Warning : No '\' between [INSTALLDIR] and AppFolder
In fact, I tested it at first with {} instead of [] so, it didn't work Smiley Mad
Note : [TARGETDIR] is a more general path
Thanks to rolfk.
Message Edité par J.DECHET le 12-29-2009 12:32 PM
Could I suggest it as solution or is only reserved for moderator?
Message Edité par J.DECHET le 12-29-2009 12:35 PM
(3,193 Views)
You are the one that decides whether it is a solution to your question, so go ahead and mark it as such if it solved your problem.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,169 Views)
