‎12-28-2009 10:15 AM
I know that the subject was already posted but not completed for my case, somebody could help me on this problem, please? Previous post
Thanks.
Solved! Go to Solution.
‎12-29-2009 03:51 AM - edited ‎12-29-2009 03:55 AM
J.DECHET wrote:I know that the subject was already posted but not completed for my case, somebody could help me on this problem, please? Previous post
Thanks.
Have you tried to create a registry key with [TARGETDIR]\\<Your app name> in the installer? The whole installer business is after all based on MSI so you best try to find how that would be solved in MSI and try then to apply that knowledge in LabVIEW.
And reading through one of the posts it would seem to me that this suggestion was already sort of linked to in one of the posts. If this can't be made to work in this way then I'm afraid there won't exist another solution directly in the installer, but I do think it will work.
‎12-29-2009 05:30 AM - edited ‎12-29-2009 05:35 AM
Yeeeeeeeeeeeeeeee, find!
You must use [INSTALLDIR] as root of key data.
[INSTALLDIR] corresponds to the user selcted path for installation.
Create your key AppPath then name it [INSTALLDIR]AppFolder\AppSubFolder
where AppFolder and AppSubFolder is your relative path
Warning : No '\' between [INSTALLDIR] and AppFolder
In fact, I tested it at first with {} instead of [] so, it didn't work ![]()
Note : [TARGETDIR] is a more general path
Thanks to rolfk.
‎12-29-2009 09:20 AM
