Binary Indicator for Digital Output Device
This probably simple question to most of people but there is always a first time to do a new thing/thing that we never have done.
I have NI 9472 which is a digital sourcing device, I have no problem to control it using LABView to output the result (line 00000000).  I also would like to have some indication on the computer screen using LED array.  I am able to create an binary array indicator but fail to connect the decimal input to the binary array.
Please help/provide some hints, it is appreciated.
Message 1 of 11
(6,172 Views)
Accepted by topic author muahang1234
Number to Boolean Array in the Boolean palette.
Message 2 of 11
(6,158 Views)
Thank you very much!!! Just an additional question - how can I reverse the binary indicator - the MSB is now at the end. I tried "reverse 1-D Array" but still the same.
Message 3 of 11
(6,152 Views)
You use reverse 1-D array.  There is no way it's the same unless that happens to be your bit pattern.  Post an example.
Message 4 of 11
(6,143 Views)
Message 5 of 11
(6,140 Views)
Your understanding of LSB and MSB are backwards. The LSB is on the left. Why don't you simply use a numeric indicator set for binary display? Otherwise, someone who actually understands how an array is displayed, is going think something is wrong.
Message 6 of 11
(6,131 Views)
How do you figure you are losing a bit?  Your original screenshot showed 8 LED's.  Converting to a U8 gives you an 8-bit number.  I don't know why you are starting with a U32 array.
Message 7 of 11
(6,128 Views)
oh - I missed count the LEDsSmiley Embarassed
Message 8 of 11
(6,123 Views)
I'm with Dennis.  Just use a numeric indicator.  Set the representation to U8.  Right-click on it and select Visible->Radix.  Right-click again and choose Display Format.  Choose the Advanced editing mode and put in %08b.  The result will give you an indicator like this.
Message 9 of 11
(6,105 Views)
Thank you very much.  It is not how to present the data to myself but how to have a meaning full indication to user.
I really appreciate all the help
Message 10 of 11
(6,099 Views)
